It is currently Tue Aug 12, 2025 4:31 am
Post new topic Reply to topic  [ 44 posts ]  Go to page Previous  1, 2
 Post subject: Re: Set up for candling?
PostPosted: Fri Dec 06, 2013 12:34 pm
First name: Wendy
Last Name: W
State: Arizona
Pat, I love that! Can we see a picture of the back side? Is it just leaning against the shelf or does it have supports that hold it at that angle? I'm getting tired of cranking my neck to get the sun at the right angle in my sliding glass door. Thanks, Wendy
These users thanked the author WendyW for the post: Pmaj7 (Wed Aug 03, 2016 12:18 pm)
PostPosted: Fri Dec 06, 2013 2:38 pm
First name: Ron
Last Name: Belanger
I use a 2ft square florescent fixture that I put a piece of white translucent plexi over. I've also use it for sorting and viewing photo transparencies. Works great for both.
PostPosted: Fri Dec 06, 2013 4:54 pm
Last Name: Keith
This is my set-up. I "borrow" a pane of glass from the shelves in the background and place it over a pair of aluminum beams (2x4's would work too). I use a 2' fluorescent work light under the glass for illumination. You can see my shooting board at the end of the dining room table.
PostPosted: Fri Dec 06, 2013 8:47 pm
like most of the posters I strongly endorse and apply the k.i.s.s. principle and use any ready light source depending on seasonal factors and time of day, i.e., bright window on sunny days, or a light fitting if the day/time of day is dark.
no worries about getting a light box out or it taking up other wise useful space, and etc.
one does not require a special piece of equipment for ever task no matter how mundane.
PostPosted: Fri Dec 06, 2013 9:31 pm
I am 180° on this subject. I have never understood the candling thing. I don't know a single woodworker who uses it for thin stuff such as guitar tops and backs. In fact my understanding of the term candling is that it was used to see how thin wood was as in a violin top when one was carving. Anyway I do hold things up to light if they are thick and not warped but not something as thin as guitar plates. If they are warped the wankyness is magnified when you unfold the book match and if you don't hold them just perfectly you don't get a good reading. You can take two Starrett straight edges and hold them up and get weird readings if you don't hold them right. It is very awkward to say the least. You can get away with the awkwardness by using a light table, a window is still pretty awkward , but to me it is complicating things.
One can simply brace one of the two plates and push the plates together with a finger or thumb and then examine the joint. You can see if it is tight or not. If you can see a joint, it isn't tight enough. You can push the wood at the joint and feel when it is rubbing and tight. (a little warpage helps here) Sometimes you can see what looks like a joint line but it is because one of the two pieces of wood is above or below the other. Push at that point and you will see and feel if the wood is touching or not. It is harder to explain than do. It is using your feel as well as your eyes.
You can feel how tight the joint is. Even if I used a light table and saw no light I (personally) would not trust that. I would want to feel the joint by tapping and pushing on it. I get a lot of feed back that way.
Anyway, another way to do it without light tables, windows, lights. IMO more unnecessary stuff.
L.
PostPosted: Sat Dec 07, 2013 5:09 am
First name: Tom
Last Name: West
State: Nova Scotia
L.
I must say I'm with Link on this one. I use overhead lighting and also the feel technique, especially on the ends of the joint. Jigs and fixtures certainly have a place but for me space is limited and I pick and chose carefully the ones I build. I tend to limit them to jobs with high risk or jobs that have troubled me in the past.
Tom
PostPosted: Sat Dec 07, 2013 10:51 am
First name: Rusty
I agree. Light boxes , fixtures, are not necessary but for me as important as the light source is the ability to easily place the plates flat on the box with no misalignment problems at all compared to holding them freehand in the air.
When I first started, I found I could manipulate the visible gap way to easily without my even trying. The light box eliminates that problem for me.
PostPosted: Sat Dec 07, 2013 10:58 am
Last Name: Keith
Same here. The pane of glass just gives me a flat surface to place the wood on. When I'm done it goes back on the shelves.
PostPosted: Sat Dec 07, 2013 12:13 pm
First name: Eric
Last Name: Reid
City: Ben Lomond
Zip/Postal Code: 95005
L.
Amen!
Pisses me off when some guy calls himself a woodworker, and all he's built is a bunch of guitars and fiddles and stuff--never made a kitchen cabinet in his life.
PostPosted: Sat Dec 07, 2013 12:32 pm
First name: Eric
Last Name: Reid
City: Ben Lomond
L.
Don't get me started about Starrett straightedges. Light goes right through them.
PostPosted: Wed Aug 03, 2016 12:16 pm
Sorry Wendy, i was overseas when you asked about it and I meant to do it when I got back but.......
Looks like answering posts are taking as long as some of my guitars!
Yes, it looks just like it is; 2 of those cheap battery-powered LED thingies. It just leans against a shelf and a bench dog in front. Works great, although not real rugged!
PostPosted: Wed Aug 03, 2016 12:43 pm
Nick Royle wrote:
Last time I just put a lamp under my workmate! Worked well.
Brilliantly simple and yet another use for such a useful workbench.
I use a window but I think I will try my workmate next time.
PostPosted: Thu Aug 04, 2016 5:02 pm
First name: Wendy
Last Name: W
State: Arizona
Wow, haven't been spending much time here, taking a break from building. Happened to check in and find an answer to a question I asked almost 3 years ago! Thanks Pat!
These users thanked the author WendyW for the post: Pmaj7 (Thu Aug 04, 2016 9:40 pm)
PostPosted: Thu Aug 04, 2016 5:41 pm
That's what I've done since the original post, 20" striplight underneath and 4mm perspex sheet on top.
PostPosted: Thu Aug 04, 2016 10:00 pm
First name: George
City: Seattle
Unacceptable! gaah gaah gaah
All kidding aside, it's good to see you posting. Hope you get back to building soon. [:Y:]
Oh, and I use a window. Seattle isn't far from Scotland and this works just fine. :D
George :-)
PostPosted: Fri Aug 05, 2016 6:07 am
:) When I was building it was often done at night. I remember going outside and driving the car on the lawn and aiming the headlights at the living room window so I could candle my plates on the window.
I hated noting the gap, marking, putting it down, going back outside and parking the car, going into the shop and using the plane some more and then repeating the entire process of getting the car on the lawn again, etc..... :shock: :D
If you ask why I didn't leave the car there until you were done I'm going to scream...... gaah pfft [headinwall] laughing6-hehe
Anyway my buddy Link turned me to the concept that we can easily see the joint very well simply by inspecting it closely. That's how I did it ever since and it works great, saves gas, you don't have the neighbors upset that some weirdo keep driving his car on the lawn and only has his boxers on..... Lutherie requires sacrifice ya know... :? laughing6-hehe
PostPosted: Mon Aug 08, 2016 4:51 pm
Overhead lighting works. Pretty simple for me, just hold the plates up to the light. Takes a little skill holding the plates together so that one can candle with some accuracy, but not particularly difficult and like anything else we do a bit of experience goes a long way. Takes all of 10-15 seconds to check a set of plates this way. I'm not sure I get the cabinet references, even though I've built them - I guess I find certain dimensions more critical than others in one application versus another. Each to his or her own.
Andy
PostPosted: Mon Aug 08, 2016 6:24 pm
First name: Josh
Yeah I have a lot of overhead lighting in the shop and so I do the same; just hold them up.
I've thought many times about building a dedicated lightbox but with the size of my shop I have always dismissed it as a nice-to-have that I just don't have the space for. In the dream shop of my imagination the lightbox is recessed flush into the top of a secondary or teriary bench. But currently any spare benches are busy serving their primary duty as shelves :D
PostPosted: Tue Aug 09, 2016 4:12 pm
First name: Toonces
Last Name: the Cat
City: New Smyrna Beach
State: FL
If you joined hundreds a tops a day -- then I can understand having a nice setup. But I think such a setup is absolute overkill for anything but factory settings.
All you need is one bright shop light. I use a clip on shop light that is easy to position - it has a 60 watt bulb. Prep the joint, use 3 strips of binding tape to hold the plates together. Here's the key point - just turn off all the other shop lights and then examine the top with just one light source. If you have lots of windows this might not work but I think for most of your workshops this will be fine.
These users thanked the author Toonces for the post: Alex Kleon (Tue Aug 09, 2016 4:52 pm)
